Service Engine Light Switch?
Is there a hidden switch on the '96 4 door Tracker that will turn the "Service Engine Soon" light off? It really bugs me and black tape isn't a good option.
Re: Service Engine Light Switch?
i had the same problem with my 95 tracker ,the switch on it is located behind the drivers side speaker ,take it out and it is behind there ,had to go to a dealer to find that one
I wore the hide off my fingers trying to find that dang switch in the left speaker hole! How about a little more detail on exactly where it is. I appreciate your input.
take the speaker out and the panel under the steering wheel and it is between the 2 openings , some 96 models have it some dont , if you dont then you have to have a scan tool to reset the light , you can go to your local autozone and they can do it for you
1986 Kawasaki ninja ZX1000R 1989 Honda Civic HB |
Unfortunatly unless you know someone at Autozone, they will not reset it for you, they are not allowed, another one of those things where one person took advantage of it, and there was a lawsuit involved, and now they are not allowed to reset it anymore. |
Re: Re: Service Engine Light Switch?
Re: Re: Re: Service Engine Light Switch?
the switch is small about an inch long , the body is black and the switch you slide is red , its just like a on/off switch , if you can clear the codes with your scan tool then your tracker dosent have the switch
just because you can clear the codes dosen't mean you don't have the switch however if it is manufactured date is after 7/95 it does not have the switch and try unhooking the ground side ove the battery with the headlight switch on for about 10 min this will completely reset the ecm making search for the o2 sensor again and if it comes back on keep in mind that some of these trackers have 2 o 2 sensors 1 in the exuast manifold and 1 behind the cat hit me personal message after you try that
The ecm did clear but I haven't checked the sensors yet. I'll keep you posted. Thanks a bunch!
Charles Quote:
why don't you just take the light bulb out of the check engine light on the panel?
on anything newer than 96 it won't pass state emissions with the light on and the bulb isn't how it tells the ecm tells it so removing the bulb solves nothing
