Old 06-19-2005, 02:11 PM
alphalanos alphalanos is offline
finally fixed comp....RAM question?
i finally got this computer working....it was a peice of crap RAM stick that was either bad or not otherwise working with the other one i had. so im back down to 256mb (ewwww) heres the question...since my other ram stick wouldnt work with this one, should i just buy a new one and see if it works? or should i replace ALL my ram? i def want 512+.
probably just buy a new 512 then later another one... whats a good brand? i had some cheap RAM before so thats probably why it messed up.
96 EJ6. Future home of boosted B18C1.
Old 06-19-2005, 06:09 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: finally fixed comp....RAM question?
Always buy name brand (corsair etc) RAM is the lesson!! Same with power supplies!!
Is your motherboard dual channel? In that case, just add as much RAM as you can afford. If not, replace with a single larger chip.
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 06-19-2005, 09:32 PM
yeah ill stick with good stuff now. yes its a dual channel
Old 06-19-2005, 10:47 PM
i was looking at the manual for the motherboard and it says this:
4 DDR DIMM slots: DDR1,2,3,4
2 slots support PC3200, max 2 GB
4 slots support PC2700, max 3.5 GB
so does that mean i can use either:
2 sticks of 3200
4 sticks of 2700
in that case i would probably get 2x512MB 3200.
Old 06-21-2005, 12:48 PM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
As far as good brands go there a quite a few out there: OCZ, Muskin, Corsair, Geil etc...
Right now you can buy their value series for about 80-100 USD. Newegg has corsair value on sale for 78 now (http://www.newegg.com/Index.asp?page=1).
If you want more serious performance OCZ gold series are the best bargain since they are BH5 based great both as stock settings (22251T) and as far as overclocking goes. They are the current fav in the DFI comunity.
Mushkin black level II are also a great choice since they are TCCDs on brainpower PCBs an excellent combination.
For serious ovecloking you can also go with the VX series from OCZ or its equivlent Redline from Muskin. They both offer full warranties even with hight voltages and increased clock speeds but they do require active cooling and are very expensive.
Btw after you buy the new mem make sure to DL memtest 86 burn the iso to a cd, boot off it and let it run a few cycles to make sure you have 0 errors.
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
