Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-19-2005, 01:53 PM
greginportland greginportland is offline
Question ALternator Testing and Loosening belt to remove
93 GMC Jimmy 4.6Vortec W
New Battery is just above 12 volts w/ engine running and off. From what I've researched here, I'd guess my alternator is failing and sucking my battery dry. Just replaced the battery, which was hovering at 10volts before it died while at a red light and would not hold the charge once installed.
My Haynes manual says I likely have the newer CS alternator which has to be taken to a dealer or automotive shop to be tested. I thought I'd check in here w/ the Jimmy Guru's - who so graciously helped me succesfully replace my CPI unit recently - before I take the truck in.
Second - Can someone tell me how to loosen my belt so I can remove the alternator (assuming it'll need to be replaced). Here is my configuration diagram w/ letters in case you can simply let me know which one I need to loosen. Over my head? Not with your help!
Oa Ob(alternator)
Oc
Od
Of
Og
Oh
Thanks for your attention!!!!
Greg
Old 06-20-2005, 09:35 PM
DelCoch's Avatar
DelCoch DelCoch is offline
Lightbulb Re: ALternator Testing and Loosening belt to remove
Autozone will check it out for you for free and will also install a new one, if needed, at no cost on labor.
Old 06-20-2005, 09:45 PM
JackDaniels386 JackDaniels386 is offline
I dont know about installing it, but yea, AutoZone checks it for free. to remove the belt, I dont know how yours is set up, but ive seen 2 different ways. If yours has a automatic tensioner, just loosen the tension on it by turning it with a ratchet with no socket or a belt tool counter clockwise. the other way is that the alternator itself is the tensioner, if thats the case you just need to loosen the bolt on the bracket and move the alternator down some to take the tension off, then take the other bolts off and remove the alternator.
Old 06-23-2005, 12:35 PM
troubles789 troubles789 is offline
My 93 w motor uses a tensioner with a socket. Rotate to loosen and same to get new belt back on.
