Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-19-2005, 12:41 PM
jubill42195 jubill42195 is offline
Angry 96 ciera won't start
My '96 cutlass ciera, will not stay running. It will turn over but it will not run for even 30 seconds. We checked all the sensors, they are fine. We checked the fuel pump, and filter they are ok too. We checked the fuses, they are ok. No one can figure out whats wrong with it. Not even our mechanic friend down the street. He checked all the sensors, checked the pressure, for the fuel pump. It was good. We did replace all the sensors. The car won't even stay running long enough now, to check anything else. I don't know much about cars, but the car ran great in Jan. 2005 when we moved from Ohio to Florida. Then we were here about a week, and it started stalling all the time. We had to put it in neutral and rev the motor to keep it running, just to get it home. The car has been sitting in my driveway since Feb.2005 and no one can figure it out to this day. Our next attempt was to replace the computer in it. Does anyone have any suggestions. I'm about fed up with this car. I only had it for 2 months then this problem. If you need anymore info about it, just let me know. I'll give you all I know.
Old 06-19-2005, 07:59 PM
Stormysdad Stormysdad is offline
Possible IAC not working, throttle position sensor not working, fuel pump failing, or failed diaphragm in EGR valve (don't remember which style this year had). Have a GM Dealer hook up a TECH2 and take a snapshot as it starts. Can't be too much looking to do if it won't run for 30 secs.
Old 06-19-2005, 09:22 PM
SupremeCutlass's Avatar
SupremeCutlass SupremeCutlass is offline
Some bad fuel pumps will go out after a few minutes of running, but will run OK initially. That's my guess.
Old 07-21-2005, 03:13 PM
jimsull2000 jimsull2000 is offline
I've got the same problem. Have you resolved things yet? What was the solution....thanks...
Old 07-21-2005, 05:37 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 96 ciera won't start
It really needs to be scanned. On some cars, there's a switch that'll stop the fuel pump and cut the engine off if it doesn't "see" any engine oil pressure in a short amount of time. If the oil pressure comes up on the instrument panel when the engine starts, you might try checking the fuel pressure while the motor's running and see if it looses pressure when the motor dies.
Old 07-22-2005, 02:10 AM
Scootzilla Scootzilla is offline
Send a message via AIM to Scootzilla Send a message via Yahoo to Scootzilla
Well i would say it is the fuel pump but i could be wrong also check the FPR fuel press reg to see if there is any air in it.Plug what is the psi of the fuelk pump put a guage to it and see what it is putting out if low get a new 1 and a new fuel filter.
Ps also some fuel system cleaner helps alittle sometimes to if it is clogged.
Scoot
Old 07-24-2005, 10:24 AM
Fuel pump solved the problem. Thanks for the help...
