Old 06-19-2005, 12:41 PM
GBeers GBeers is offline
2001 sunfire won't start 2.4L
Hello
My sunfire Didn't want to start then after about a min or two it worked fine. Then the next morning, NO GO. I've changed the crank sensor and the fuel pump is coming on when I turn on the key. I don't know what it is, any ideas?
Old 06-19-2005, 03:58 PM
deadBird's Avatar
deadBird deadBird is offline
Re: 2001 sunfire won't start 2.4L
If it dies right after going >55mph then it's your TCC solenoid.
Old 06-20-2005, 04:58 AM
I would be happy if I could get it to 55. It doesn't just doesn't. It did this a couple of different times to me now. I had it towed to the dealer and it started fine and ran fine for a month. It runs ok after starting.
I tried changing the plugs, and I have spark to all plugs.
Old 06-20-2005, 05:01 AM
robzone0911 robzone0911 is offline
When was the last time the fuel filter was replaced?
1...2...3...go! 16.3@85mph 2001 Cavalier Z24 Happily traded for my Z32
Old 06-20-2005, 05:29 PM
deadBird's Avatar
That or a weak pump.
Old 06-20-2005, 09:08 PM
I replaced the fuel filter 2-3 months ago. It finally started today, I'm thinking it is an electrical problem cause today was the first dry day in a week.
Old 06-20-2005, 11:36 PM
deadBird's Avatar
Then it's more than likely your ignition coils. Also, maybe replace the spark plug wires with non-cheap ones also...
