Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 06-19-2005, 11:56 AM
emailj emailj is offline
Passenger side window
Hey dont know if anyone has had this problem, but my Passenger side window is very hard to put up (once it gets half way) the bottom half is no problem, you get it half way up and its really hard. Any ideas?
Old 06-21-2005, 11:37 AM
sudsy49 sudsy49 is offline
you didnt say if you have power windows, but if you do it sounds like the power window motor & cable assembly is junk! Mine went on my 2000 sierra at 50,000 miles. you can get an aftermarket unit at 1A auto.com for 80 bucks.
Old 07-10-2005, 09:53 AM
gmtech79's Avatar
gmtech79 gmtech79 is offline
Re: Passenger side window
Make sure window is not binding in track.
ASE Master
ASE Advanced Engine performance
GM World Class Technician
1978 Pontiac Trans Am
1984 Monte Carlo SS
1991 GMC C1500
2002 Pontiac Grand Prix
Old 11-23-2006, 01:40 PM
ark 1 ark 1 is offline
I have a 88 sierra 2500. every time my son borows it something breaks. The last time it was the passenger side power indow. It went down but wouldn't go up. The bigest problem was in the driver door where the main power wire fed into about a dozen others. The passenger side is controlled from driver side. The power wire is soldered to a gang of other wires, each one feeding a seperate switch in the side panel and returns through another wire in enother harness to the passenger door. This could have been easier if they had daisy chained the switches. This is the second time I have had to repair this splice. I don't have time to deal with it now. But when I do I will lengthen every wire in this circuit so the harness plugs do not meet in the flex tube between the door and the jam.
