Oil leaking into Spark Plugs, Help Requested
This should be a simple question, because I know a decent amount about cars.
Basically I have a 1995 200sx se-r. Oil is leaking inside the engine onto the spark plugs, all over the tips. So, question is, which gasket do I replace? I have heard the "Valve cover/seal gasket" others have said replace the head gasket ( found here http://www.partsamerica.com/ProductD...pe=100&ptset=A ) Quick help would be greatly appriciated as I need to get this baby ready for a LONG drive. |
Re: Oil leaking into Spark Plugs, Help Requested
If it's all over the tips, I'd say it the head gasket. If it was all over the wires, it would be the valve cover gasket.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec. VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec. ![]() Don't make me ANGRY Or I will kick you in teh NUTS Your NUTS will feel teh steel toe Teh steel toe that has been in teh snow I will rip off yuor pants and kick yuo in teh nuts My steel toe will stick to yuor nuts And I will swing yuo around by yuor nuts as I do a Hurricane kick |
Unlikely it is the head gasket or valve cover gasket. It is problaby the sparkplug tube o-rings. If the oil isn't burnt on it, then what happened is that oil inside the valve cover is making it past the o-ring seals for the spark plug tubes. You still need a new valve cover gasket since you have to pull it to get to the seals.
Yes, you're right, I just wasn't getting that specific. I consider all 5 gaskets the valve cover gasket since most people would replace them all.
