Old 06-19-2005, 07:36 AM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Pinging even though it's timed right
Two weeks ago I had to replace the entire dizzy cause of a code 8. After we put the new one in and timed it correctly, I took the car for a test drive and the car just pinged like crazy. It is actually so noticable that people will actually look at me. I tried a higher octane but that didn't help. What should I be looking at doing here?
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 06-19-2005, 12:42 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Pinging even though it's timed right
I know you said the timing is right, but it sounds like the timing is advanced slightly - I dont know of anything else that would cause it to ping.
Old 06-19-2005, 03:37 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
I'm having a similar problem my d15b1 started pinging shortly after an mpfi swap ive narrowed it down to one of two things. I think my fpr is shot so i might be running lean. Or something is wrong with my ecu because it wont go into base timing when i put a jumper wire in the connector. And according to my advance timing light (the kind with the dial on the back) i'm running like 5 or 6 degrees advanced way too low and the highest i can go is 10 then it will ping crazy loud and if i retard my timing it will bog. btw high octane fuel worked for a little while but isnt anymore. Also i burn a little oil so I dont know if that could also cause it to knock. Well sorry bout' the long post this may help or maybe i could get a little help.
Steve
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 06-20-2005, 04:10 PM
Shaguar47's Avatar
We checked with the timing light and it's right on the red dot on the crank pulley. I do know that I'm leaking oil into the spark plugs cause the seals are bad. Could that be the cause of it? Also my neighbor said he had a pinging problem and it turned out to be his catalytic convertor.
steve-o317, what is a fpr, I've never seen that term before?
Old 06-20-2005, 04:24 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Re: Pinging even though it's timed right
Don't leave the 4th gen forum much do you j/k
FPR is short for Fuel Pressure Regulator.
Old 06-20-2005, 06:02 PM
Forunn Daberator
Did you disable the advance when you put the timing light on it?
Old 06-20-2005, 06:35 PM
Shaguar47's Avatar
Yeah, we made sure of it when we timed her.
Old 06-20-2005, 09:29 PM
thanks spoon for covering that question
Also I too tried disabling the advance but for some reason it wont work i did an mpfi swap and I've checked all the wiring 3 times and its all right. But when i put in a jumper to disable the advance it does nothing. I'm beginning to wonder if I have a bad ecu somehow? because I've checked the continuity all the way to the ecu and when i put in the jumper it has perfect continuity.
Wow Btw i didnt mean to steal the thread maybe i'll make my own about this someday if i cant fix it.
Steve
89 std hatch back
D15B1 4 speed
MPFI Swap
Old 06-20-2005, 09:44 PM
Forunn Daberator
Its not going to be in advance all the time, you wont notice a differnce when you jump it.
When was the last time you did a good tune up shag?
Old 07-16-2005, 11:41 AM
Shaguar47's Avatar
Well, I've changed the seals and crap on it but nothing to major yet. Someone told me it's my catalytic convertor but I don't think it'd be that. I do believe it might be that my valves need to be adjusted correctly.
Old 07-16-2005, 04:26 PM
CBURKE's Avatar
CBURKE CBURKE is offline
bingo...... I'd try that.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
