| Off-Topic Talk about anything other than cars. |
Ok heres the deal: I just picked up a newer Pioneer cd player from a friend of mine who had it installed in a saturn. He had it professionally installed, so when I pulled it out, I noticed that the wires that werent used on the harness plugging into the pioneer were capped off. These wires were:
yellow: battery I think (don't you need this?) red: auxilary? blue and white: no idea All the rest of the wires were hooked up, and I bought the factory adapter so I wouldnt have to chop off the factory harness. I hooked up all the wires: black (ground) white purple green grey etc.... I didn't use orange, brown, or blue. Not needed as far as I know, and there were none of those colors coming from pioneer harness. Heres my problem: I am getting no power at all to the unit. I plugged everything in, and nothing. Not when the key is in acc. or started. What did I do wrong here? I know the damn thing was working when I pulled it out. Don't I need to connect the yellow wire for power? Why the fuck was it capped off if I need it? HELP ME OUT!
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Re: Aftermarket Radio Install: Need help now
What do you mean you hooked up all the wires? Are you using a harness? Get some instructions, or at least another pioneer's instructions because they are probably the same.
the blue and white were for power antana and the remote for amps.
red is usually the main power wire... but at any rate start small... check the fuse 90% of the time that is what is wrong. unless you acctually took off the "-" termenal lol.
![]() 1990 Honda Civic Hatch - 3 motors, SOLD 1998 Honda civic EX - nothing done, SOLD 1990 BMW 325IS SOLD 1992 Plymoth Laser RS SOLD 1992 Mazda Pro-to-gay Given away 1995 Saturn SL2 SOLD 2002 Toyota Camry LE V6 bone stock. |
your yellow and red wire are power wires.
most people forget to ground the black (ground) to the car.
Yeah i had grounded the black wire to a metal screw. That's good enough right?
I am using 3 harnesses. The stock harness that plugs into the stock radio, the harness adapter that plugs into the stock harness, and the harness that plugs into the pioneer cd player. I am connecting the wires from the pioneer harness to the harness adapter. If the red and yellow wires are power, then why were they capped off when I pulled them out of the saturn? I saw the cd player working perfectly in his car. That dosn't make sense, wouldn't he need to have those wires connected also? How was he getting power to his unit?
I don't know if this will help
When I cut my wires to hook up my radio I noticed that the factory red wire was my yellow wire and the factory thick light blue wire was my red. yes the screw is good enough for the ground. Well is is for me.
Take a look here, everything should be explained http://www.installdr.com/Harnesses/M...shi-Wiring.pdf
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister |
Re: Re: Aftermarket Radio Install: Need help now
I hooked up the red wire. This did nothing. Now the only wires not hooked up coming out of my pioneer harness are blue/white and yellow. I'm starting to run out of options. There is no power to the unit at all. The fuse on the unit itself is still good, and there is nothing blown in the car, because I reconnected the stock head unit to make sure. Stock unit gets power. Any ideas?
The yellow wire on aftermarket decks is usually the +12 Volt battery wire, and the red +12 volt ignition wire. Try connecting the yellow wire from the deck to the red w/black stripe wire. Even if you still have the harness hooked up, the link in my last post is a good reference. If you took a good look @ it you would have found out that the yellow wire you didn't connect is your problem. Over the past 10 years i've gone through 6 decks, and the wires on all of them where colour coded as installDr states (Where it say's "Typical new radio equivelant wire colour")
How did my friend have it hooked up and it ran perfect with NO yellow and NO red wires connected? This really stumps me. Neither were connected when I pulled it out of his car. Thanks a lot for your help.
There are only like 4 wires that aren't for speakers: Power, ground, dimmer, amp remote. Any more slip my mind. Power should be red, ground black, dimmer orange or yellow although I never connect this, amp remote is usually blue/white.
We are talking about wire colors from an aftermarket radio to an aftermarket wiring harness, so there are no eclipse specific colors involved. You need power AND ground for the thing to turn on. Once it's on, if you don't think the colors are matching, plug in the SOLID and SOLID/BLACK meaning positive and negative for each speaker and test them. Use the radio's fader/balance and figure it out... not that hard. |
Factory harness plug that I didnt cut - Factory Harness Adapter plugged into the factory harness - wires connected with Pioneer wiring harness I have the red connected, and the black is grounded to a screw. The only colors not connected are blue/white and yellow. There are no orange wires coming from the pioneer wiring harness. There are several unused wires coming from the adapter I bought: solid blue brown orange orange/white stripe yellow Tomorrow I will connect the yellow wires, and hope this gives me some life in the unit. I don't have a digital camera, so I will try to take pictures on my phone and transfer them to my computer and upload them. They might be kinda shitty and small, but it's worth a shot.
Re: Re: Re: Aftermarket Radio Install: Need help now
Ok disregard everything that you've heard because I'm going to walk you throug this step by step. OK to answer your question about the the red and yellow wires. Red is usually ACC +12V that means that it is connected to the accessory +12V which is run through your ignition switch. That is what turns the radio on with the car so that it's not on all the time. Next the yellow wire is your constant +12V source. This is a direct connection to the + terminal of the battery. This constant +12V is what allows the memory of your CD player to work after you turn the switch off for the Ignition (programmed radio stations, current playing track and so on). On the wiring harness that you bought to fit onto your stock harness there should be a connection for both of these. The ground you have is good as long as it's connected so that it can't come loose. It is vital to connect both the red and the yellow wires because you cannot operate without both connected. I need you to post or pm me a listing of what the instructions say that the color codes are for the adapter that you bought. Next I need the model number of the Pioneer that you bought and if you can find it, there are usually wiring diagrams on a sticker on the top or bottom of the radio that explain the color codes for the specific wiring harness that the radio uses. List those as well if you can find them if not I'll try to find them for you. After that I can walk you the rest of the way if you still need help.
Wow, this was excellent help. The adapter that I bought came with no directions on what color was what, it just came in a plastic bag with some brand name on it. That was it.
The model pioneer that I have is deh-p7400 (kind of old, but couldn't pass it up for $50). I didn't see any color coding sticker on the unit itself. I have a friend who has the deh-p750, but he couldnt find the instructions for it, and the guy I bought mine from lost them a long time ago. I really appreciate your help. I will go and connect the yellow wire right now, and see if that works.
OK I have power! And everything seems to work.
Is the antenna supposed to stay down when the radio turns on? How the hell do I mount this thing? I can't find any screw holes on the sides of the unit. You guys have been a big help so far. I'm almost done. Thanks.
