Old 06-18-2005, 11:52 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Cat options
Where online can i get a decent Catalytic? went to a couple shops but i dont want to have to weld it on. want one with flange so it will bolt up to piping. Also how much Oem o2 cost roughly? worth extra to go with Oem oppose to Bosh? Hatch at the moment runs good but Cat shot and makes all kinds of noise and i figured i would change o2 cause Runs really rich!!
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 06-19-2005, 12:21 AM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Cat options
you can get a catco high flo bolt in cat for around 120 i believe from summitracing, thats what i use.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 06-19-2005, 12:40 AM
ef four door's Avatar
ef four door ef four door is offline
i got mine from carparts.com for $104 shipped. shipping kind of lags tho.
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
Old 06-19-2005, 01:47 AM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
Re: Cat options
fukk it straight pipe the dam thing
90 nissan 240sx
Basically Bonestock...
Drop In K&N Filter...
243,000 miles on the odometer!!!
Still Runnin Haha
17' Racinghart CR5 Black Polished Lip
Old 06-20-2005, 07:50 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Cat options
1 wire O2 sensor from Honda is same as Bosch so don't waste $
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-20-2005, 09:37 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
well last time i said this i got flamed but right now im running a straight test pipe and when i get my cat back i will use a cheap egay high flow cat and hope it sorta works like a resonator
BTW I dont have to deal with emissions if you do probably the catco would be best
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 06-20-2005, 10:02 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Cat options
If its making noises its more than likely the heat shield, can easily be fixed with some hose clamps.
Old 06-21-2005, 01:44 AM
89si's Avatar
89si 89si is offline
hose clamps eh? i get a really ugly rattle just below 3 rpms, and then up around 6 when im pinning it. ruins my smooth sounding exhaust.
by hose clamps, do you mean those metal circle things you tighten with a screw driver? just a guess.. i've been trying to avoid the rattle rpm in the meantime.
89si-
78000kms on original engine.
sub is in.. lights are just about done..
Old 06-21-2005, 11:31 AM
Forunn Daberator
Re: Cat options
Yeah just get a couple of big ones, you can buy them at most hardware stores. If you cant find any really big ones you can link smaller ones together. Put them all the way around the cat and tighten it. Keeps the heatshield from rattleing.
Old 06-21-2005, 05:20 PM
89si's Avatar
sweet. i'll get some of those for sure, i never thought of that.
so just wrap them around the heat shields and tighten them really well?
89si-
Old 06-21-2005, 05:41 PM
Forunn Daberator
Re: Cat options
Yup, most of the time that will correct the rattle.
Old 06-21-2005, 05:52 PM
89si's Avatar
Re: Cat options
awesome. thanks TSC.
89si-
Old 06-23-2005, 02:00 AM
fierangero's Avatar
fierangero fierangero is offline
Send a message via AIM to fierangero Send a message via MSN to fierangero Send a message via Yahoo to fierangero
Re: Cat options
unless its the element inside like mine was...replaced full exhaust except resonator, too bad some of the cat element blew into the resonator so it still rattles
Rest In Peace, Rich Hall
my baby: 1986 Fiero GT: v6, automatic, 2.8L, 2.02/1.60 heads, Crane Performance Cam, Ported/polished exhaust manifolds, taylor plug wires, low temp thermostat and fan switch. WCF catback exhaust
She's done!
Old 06-28-2005, 01:51 AM
89si's Avatar
just to follow up:
i took TSC's advice and got 3 hose clamps (yes. likely overkill) and strapped them onto the heatshields and tightened them right up, and the rattle is GONE!!
im soooooooooooo happy, the exhaust is so smooth sounding throughout the rpms, now i dont hafta try to avoid being just under 3k. awesome!!
i strongly encourage people to try this option if you have this rattling problem. if it doesnt solve it, you can always go return the clamps and get your money back. i had originally gotten one that was just too big, so i went back and got smaller ones, its so easy and cheap, and works perfect.
once again i was driving without the stereo just to hear my (now rattle-free) exhaust.
89si-
