Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 04-19-2002, 06:56 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Question Camber problem?
Okay, here is the situation:
Iīve dropped my 5th gen Lude with an Eibach Prokit and Koni yellows on stock tires/ rims. I dunno how much itīs lowered but there is a gap of two thin fingers left on the front (between wheel wells and tires) and about 1 1/2 thin fingers on the rear. Camber seems to be within specs and tire wear seems to be okay, too.
So here are my problems:
1.) I seem to have more negative camber on the rear.
2.) Sometimes the car feels `nervousī depending on speed. I mean itīs kind of difficult to keep track sometimes. (Do you know what I mean? I dunno how to explain it. )
My questions are:
1.) Should I get a camber kit or wonīt help it with my problems? And if yes, which brand? Ingalls is very expensive but I dunno if Progress (or Progressive?) or others are good brands.
2.) If I would correct most of my negative camber (I want to keep some negative camber because weīve got a lot of corners over here!) with a kit would my tires scrap on the wheel wells or even hit on them?
I really need some fast help with that because Iīm going to order a Neuspeed strut bar from the US in the next days and then I could order it all together.
Thanx in advance!
Old 04-19-2002, 09:19 AM
Veetec's Avatar
Okay, hereīs the new situation:
Iīve found my alignement printout again. Camber and toe seems to be okay on the front axle (front left camber/ toe: -0°49ī/ 0°01ī// front right camber/ toe: -0°30ī/ 0°00). Itīs a bit different on the rear axle. Camber seems to be okay there, too (rear left camber: -1°20ī// rear right camber: -1°39ī). But the toe is a bit out of spec (rear left toe: -0°02ī// rear right toe: 0°23ī).
So what is your opinion about that? Is it fine like it is now or should I change anything? Maybe the "washer trick" on the rear and then a new alignement?! Please give me some input about this because I donīt have got ANY idea.
Thanx in advance!
Old 04-19-2002, 10:09 AM
SleeperTeg's Avatar
SleeperTeg SleeperTeg is offline
**Refresh**
I have no idea, but someone help Veetec out for christ sake!!
Old 04-19-2002, 10:12 AM
Veetec's Avatar
Originally posted by SleeperTeg
**Refresh**
Yeeees, please do what SleeperTeg is saying!!! I need some help.....
Old 04-19-2002, 11:24 AM
HONDA_99 HONDA_99 is offline
if you have car manual, you should be able to find suspension tolerances for your car in there.
sorry i can not help any more, i have an Accord. Accord does not need a camber kit if its lowered with Pro-Kit, but Prelude can be different.
Old 04-19-2002, 11:52 AM
Veetec's Avatar
Thanx anyways!
Camber seems to be okay but the toe on the back axle seems to be out of specs! What would I need to do the washer trick? I think one washer on each site should be enough but what else would I need for it and is it safe?
Old 04-22-2002, 03:41 AM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
Check out my site for the rear camber trick. I'm not sure how prelude suspensions are, but if it looks the same, then it'll work
http://home.earthlink.net/~civicex95/rearcamber.html
As for the rear toe, you need to get an alignment to get that fixed. That'll wear out your tires quicker than the negative camber will.
Old 04-22-2002, 04:00 AM
buh_buh's Avatar
buh_buh buh_buh is offline
Send a message via ICQ to buh_buh
the washer trick will NOT work for Preludes. I wanted a cheap way to fix my camber too, but it will not work. After lowering your car, did you get an alignment? It may help your camber after you get an alignment. If so, I say Ingalls or Progressive makes the best camber kits. Good luck.
AF Nordic Crew #3
camber problem slammed89civic 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 05-21-2003 11:47 AM
Camber problem? Veetec Prelude 7 10-02-2002 11:04 AM
civic camber problem civicESi Tires and Wheels 1 04-10-2002 08:40 AM
Camber problems after installing AC Lift Elroy Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 12-19-2001 11:35 AM
accord camber problem ismmistic Tires and Wheels 7 12-18-2001 12:50 AM
