Old 06-18-2005, 07:48 PM
GMCTech GMCTech is offline
91 Cavalier misfire under 1500rpm
Working on a 1991 Cavalier w/ 2.8 V6.
Has a misfire under 1500 rpm at which point it appears to go away.
Scan tool shows Lean/Lean/Lean until 1500 then flags back and forth Rich/Lean properly. No Check Engine light commanded, no codes present.
The car has recently had: Head Gaskets, Intake gaskets, Heads rebuilt, new plugs, wires, coils, and ign. module. Injectors have been swapped with known good ones with no effect. All 6 cylinders 150psi on compression test.
Any ideas?
Thanks in advance
Old 06-19-2005, 03:46 PM
deadBird's Avatar
deadBird deadBird is offline
Re: 91 Cavalier misfire under 1500rpm
Hmm possibly O2 sensor(s) or EGR valve.
Old 06-19-2005, 07:22 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
a 2.8 into a 91?
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
