Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-18-2005, 07:22 PM
attillaXXX attillaXXX is offline
Spark Plug Tube - Oil Accumulation
I just purchased a 94' rodeo with 3.2L engine. I noticed oil in the spark plug tubes. Is this normal for this engine?
Old 06-19-2005, 12:00 AM
Cat Fuzz Cat Fuzz is offline
That happens when the tube seals leak. You can buy a set of valve cover gaskets and new tube seals come with the set.
Old 06-19-2005, 05:54 AM
rodeo02 rodeo02 is offline
Yep. Bad plug tower seals. Basically they are just rubber O-rings that seal the tower off from the cylinder head. I wouldn't worry about changing them out unless you have to address the valve cover gaskets. Consider that little bit of oil free spark plug never-seize !
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
