Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 06-18-2005, 02:01 PM
lbolger lbolger is offline
Angry 94 Intrepid Transmission Problem
The car has a new transmission about 6 months old. Transmission is slipping, dash guages are not working. Does anyone know what the problem could be?
Old 06-20-2005, 12:52 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 94 Intrepid Transmission Problem
When the fluid was put it, did you find out what fluid is in there? All Chrysler transmissions are supposed to use Mopar ATF +4, if not, you'll experience transmission problems. Try that first.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 06-20-2005, 08:27 AM
Question
We haven't checked that yet but will do that. I think it may have something to do with the steering column?? Is that possible? If you wiggle the ignition the transmission, dash lights and guages seem normal. My husband took it apart but is unsure exactly which part to take off.
Old 08-01-2005, 05:25 AM
cuegt cuegt is offline
Check your speed sensor
If your speedometer is not working, and your not going above 1st or 2nd gear in your trans, then the problem more than likely is in the speed sensor. I'm having the same problem as of now, I can't tell u exactly where it is, but i know it's somewhere near the Tranny. How this helps.
Old 08-01-2005, 08:27 AM
94 intrepid
We havent tried the speed sensor yet but alot of intrepids seem to have had that ptoblem. We will give it a shot. Thanks
Old 08-18-2005, 10:46 PM
Alan Ross Alan Ross is offline
Had this problem with my Sebring convertible.
I replaced the TCM, & while changing I noticed the connector was loose & had corrosion. I was upgrading to autostick anyways. I noticed a couple of grounds under the hood in the trans area were corroded. Cleaned everything up & all is well.
Check the connector on the transmission itself as well.
