Old 06-18-2005, 01:10 PM
Mikes71Cam Mikes71Cam is offline
Engine and tranny bolt on
Will my 383 stroker with 485 hp bolt on easily to a turbo 400 tranny? If so I'd like to know how hard the installation would be on a scale of 1-10, 10 being hardest.
Old 06-18-2005, 08:04 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
the difficulty would depend on what type of car, and what kind of engine, 383 stroker is just displacement... is it EFI or carb? anyway, a turbo 400 will line up just fine w/ ur engine no problems at all.
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 06-18-2005, 09:06 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
they should bolt up, if you have efi you have alot more work
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 06-18-2005, 09:37 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: Engine and tranny bolt on
EFI won't affect your tranny (not to my knowledge). You don't need electronically controlled shifting. I think you are really asking if it will hold the power okay. I don't know if it will. Is it stock? someone else might be able to help with that.
The cross-member that holds the tranny up and the driveshaft is what you should be concerned about. mounting locations on the tranny and length of driveshaft. if the car originally came with the 400 then you should have no problem.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 06-18-2005, 10:50 PM
Morley Morley is offline
A TH 400 will bolt up to a small block just fine and it should easily hold up to the power you are intending to throw at it, however HP numbers mean nothing where a transmission is concerned, Torque is what kills them.
If you have an EFI set up with a cable driven speedo you'll have no issues with the computer (just disable the TCC in the prom programming). now if you have a later electric speedometer, you are going to have troubles.
Do some looking around on thirdgen.org, several people have done a TH350 swap and a few have done the 400. You'll need a trans mount, different tail housing for the torque arm mount and possibly some driveshaft work and shifter locating fabbing to do.
