Old 06-18-2005, 02:10 AM
Riceboy891's Avatar
Riceboy891 Riceboy891 is offline
AC help!!!
First of all im not here to be told to remove my ac for weight loss and power gain, i live in ga it is very hot and humid and i need it. With that out of the way, my ac does not work and i have figured out that the compressor is not coming on. Im not sure if it is the clutch or something inside the comp. or an wire, relay, fuse. I am going to check all the wiring before i start taking it apart and replacing stuff. The problem is I dont have a wiring diagram for it. If anyone could help me with this with any info or diagrams it would be much appreciated.
Old 06-18-2005, 05:19 PM
Riceboy891's Avatar
Anybody?
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
KYB AGX Shocks/Tein Springs
"yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber
Old 06-18-2005, 09:00 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: AC help!!!
I don't have ready access to the wire diagram to post but there are some things you could check. But I think you probably don't have sufficient refrigerent. Here's how to do some basic checks on the compressor. First, check if the compressor is frozen, with engine off just grab the center section of the compressor pully and try to turn it by hand. If it turn easily then check the clutch. Connect a jumper wire from the positive side of the battery and touch the other side to one compressor clutch power wire. The clutch should click. For the relay just follow the power wire it's one near the passenger headlight. There are two relays and I think it's the one on the right.
Once you pull the relay hold it with the clip side up. The terminals are top left = 1, top right = 2, bottom left = 3, and bottom right = 4.
There should be continuity between 2 and 4. If you put 12v between 2 and 4 there should be continuity between 1 and 3.
If you plan on retrofitting to R-134a you should replace all the O-rings, install new charge fittings, a new dryer, bring it to an A/C shop to have them check your work, and get a new charge while you're there. God willing you should be all set. GL
Old 06-18-2005, 10:14 PM
Riceboy891's Avatar
thanx alot man im going to mess with it tomorow, I know it is not frozen, i have spun the center section, but ill try the other stuff, thanx again
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
Old 06-19-2005, 01:14 AM
h22hatch91 h22hatch91 is offline
Re: AC help!!!
post up what the problem was if u figure it out
Old 06-19-2005, 02:45 AM
Riceboy891's Avatar
ok I will
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
Old 06-19-2005, 12:56 PM
stickershop's Avatar
stickershop stickershop is offline
Re: AC help!!!
It's probably either low on refrigerant or the pressure switch is defective. The pressure switch prevents power from going to the compressor if the refrigerant pressure is too low. This prevents damage to the compressor.
StickerShop.ca - got stickers?
High Quality Custom Vinyl Graphics, Signs, and Banners :thumbup:
Proud owner of two 1991½ Honda CRX Si Special Edition's (sequential VINs too!)
Old 06-19-2005, 10:32 PM
johnb16a2's Avatar
Re: AC help!!!
Your Welcome! Keep us posted.
Old 07-25-2005, 04:08 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
Re: AC help!!!
my ac compressor didn't come on until r12 freon got added in... i turned the ac on at full blast. added r12 and the compressor started spinning.
Old 07-25-2005, 08:24 PM
CR50HC CR50HC is offline
Re: AC help!!!
Your low pressure (freon) switch was protecting your compressor. I would have your system checked for leaks because once they get low, they get low again and again until you repair the leak. Most likely due to a bad o-ring in your lines. r12 ain't cheap either. Might consider converting to r134 (Honda did mine the proper way for 199.00)
