Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 06-17-2005, 11:02 PM
sentrase-rpilot sentrase-rpilot is offline
Banned
Question heres the question fugiot
since you are the one that knows the most about se-r's do you know if is regular for water to come out thru the top of the small reservoir next to the radiator and next to the windshield wiper fluid, do you know why it does it?
please let me know asap/
Old 06-18-2005, 01:01 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: heres the question fugiot
ummmm spilling out the top? no thats not usual... you sure you have coolant in your radiator?
the coolant reservoir should be filled only like 1/3 of the way up. it is there to catch any coolant when the engine cools down and the water pump stops pumping it through the engine.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 06-18-2005, 03:01 AM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
it's there so there's extra room when the coolant heats up, because the volume will increase. So knowing that, the only reason your coolant would be spilling out of the top of that would be because your car is overheating. If it's not overheating, then there must be something wrong with your water pump or thermostat. Either that or you fill it up too much. OR your temp guage is broken, but not likely.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
