Old 06-17-2005, 09:53 PM
Dan89rs Dan89rs is offline
Question simple stereo problem...
i think this is pretty simple. my stereo will not keep the time or the preset stations. it is aftermarket: old, am/fm cassette, lol. i did a search and found that the orange wire is for the memory and according to the sticker on the top of the stereo, it is hooked to the right wire (gr w/ wh stripe). anyway, i checked for voltage on that orange wire with the key off. and i got 12V (roughly). doesn't this go to say that my head unit is crap? thank you for reading!
Old 06-23-2005, 01:47 AM
91camaro_rs 91camaro_rs is offline
Send a message via Yahoo to 91camaro_rs
Re: simple stereo problem...
just go get a new cd player or something and get the wiring harness for it....
is it the original head unit?
Old 06-23-2005, 01:56 AM
camaro73 camaro73 is offline
Send a message via AIM to camaro73
i had that happen to me also i had a brand new pioneer headunit that would not keep any of my stations or time, take it to a stereo shop that knows what they are doing, i found out that i mixed one of the wires up when i used the GM radio adapter that was making me lose all my memory settings, hope this helps
Old 06-23-2005, 02:01 AM
Re: Re: simple stereo problem...
maybe you can help me. My camaro wont start 99% of the time. only once in a blue moon. runs all day then quits. replaced virtually everything on it. down the the distributor or the computer. its a 91 rs 3.1
going nuts
Old 06-24-2005, 12:26 AM
i don't know much about 82-92 camaro's i have a 93 so the reason that your car isn't starting is beyond me, maybe the ignition could be bad down to the wrong firing order? does it crank over or does it not even attempt to start?
Old 06-24-2005, 09:02 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
You're backwards, the orange is battery hot, on at all times. There's a yellow wire which is the fused feed, hot only when the ignition is on. There's anotehr yellow which is left rear speker out.
