Go Back   Automotive Forums Car Chat > Isuzu > Trooper | SLX | Bighorn | Wizard
Old 06-17-2005, 05:38 PM
Troopy Troopy is offline
2000 Trooper Front Differential Maintenance
I went to drain and refill my rear and front differentials yesterday. The rear went fine. But I couldn't find a drain plug on the front. Just a fill plug. The manual states that the oil in the front differential should be changed out at 15K mile intervals. But I see no way of doing this.
Can anyone enlighten me on how to perform this maintenance on the front differential?
The Trooper has TOD and SOTF.
Old 06-19-2005, 02:47 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: 2000 Trooper Front Differential Maintenance
I ran into the same problem with my rodeo. There doesn't seem to be a drain plug for the front diff. I just ran across this last night though. If you look at the bolts that hold the diff on, the bolt located at 5 oclock is the drain plug. I am not sure if this is true, but that is what the manual I have says. It may be the same for the trooper. I haven't checked my Rodeo yet either, but I am hoping this is the case, because the drain plug will make it a lot easier.
Marc
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
Old 06-20-2005, 07:38 PM
Thank you marcre. I will try that.
Old 07-04-2005, 10:19 PM
ollopa ollopa is offline
The 5 o'clock bolt works as a drain on my '90 trooper, FYI. Just drained it last week.
