Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 06-17-2005, 04:35 PM
klone420 klone420 is offline
Question How to fix some problems with my 240
I'm havin a few problems with my 93 auto 240SX. To start I put a new aftermarket rad. on it and now the intake pipe is gettin hot because it touches the rad.(aluminum). the 2nd thing is that the tranny is leakin I think its because the last owner scraped it a few times, so now its cracked(Could be just a seal problem hard to tell without takin it apart) Dont have a welder so I was wondering if there is something i can put in the ATF to seal it. Or could I use some JB weld? (only leaks when its hot)
The last thing is that I have to replace the ball joint in the lower control arm(got one from junkyard because the one on the car is twisted,drifted into a curb to avoid bein smashed by a mack truck!) anyway I was wondering if I could press this without using a press?(got no money becuz of court,fines,lawyers,bitches,etc..) any advice would be greatly appreciated!! -about car
"And when I leave it comes together like buttcheeks"
Old 06-17-2005, 04:42 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: How to fix some problems with my 240
i replaced the ball joint in my 89 hatch with just hand tools its very possible.
the tranny fluid isnt really pressurized so it wont blow a jbwelded seal but still id just replace the tranny. you should be able to get one for less than 100 bucks. i would NOT use any ATF stopleaks because more often than not they are bullshit and are really only meant to sort of revitalize gaskets, not actually stop cracks
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 06-17-2005, 04:46 PM
Re: Re: How to fix some problems with my 240
[quote=slideways...]i replaced the ball joint in my 89 hatch with just hand tools its very possible
How did u do this?
I plan on dropin a new motor and a manual trans. just need to nigrig until i blow this one.
Old 06-17-2005, 05:17 PM
remove the pin, castle nut, and i cant remember but i think there was a snapring also that held it in the control arm. then just use a hammer to knock out the ball joint. it took me a while and a lot of penetrating oil, tons of hammering, and many many bad words, but it came out. and mine was pretty rusty as i live in MN where all cars have salt dmg
