Old 04-18-2002, 10:28 PM
rendog24's Avatar
rendog24 rendog24 is offline
what does a capacitor do for a stereo system?
i ahve no ieda what it does. does it produce more power for the subs, amps or what?
Old 04-18-2002, 11:20 PM
-=BOOMER=-'s Avatar
-=BOOMER=- -=BOOMER=- is offline
Send a message via ICQ to -=BOOMER=- Send a message via AIM to -=BOOMER=- Send a message via MSN to -=BOOMER=- Send a message via Yahoo to -=BOOMER=-
Speakers use electricity from you battery to create sound.
What a cap does it when the amp requests a large amount of power (usually for low bass notes) sometimes it takes more then the batt can supply in the amount of time the amp needs it. So your low bass notes are not as full as they could be because of lack of power.
A cap holds some energy in it for this and releases it so the amp is never starved for energy and thus your bass responses are fully developed.
hope this helps.
Oh here for a Professional responce...
look here
Old 04-18-2002, 11:29 PM
xivera's Avatar
xivera xivera is offline
What he said... (pretty much)
I'd like to mention that a capacitor is basically a [cheap (not really)] quick fix for providing more power to subs. A better solution is to rebuild the stock alternator or... get a higher output alternator which will always provide more than enough power.
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 04-18-2002, 11:58 PM
ric's Avatar
ric ric is offline
Send a message via AIM to ric
a capacitor smooths out voltage fluctuations and helps to deliver quik bursts of above average power when called upon. while a huge bass note will bog the slowly responsive lead/acid battery a cap made from paper and chemicals will be able to deliver that power much more quikly.
if you wanna help your system then start with the bottleneck most people overlook. the factory battery and engine grounds. if your headlights are dimming 9 times out of 10 replacing the battery ground with a thicker wire like a 4 gauge wire will eliminate it. trust me its worked on every car ive tried it on that didnt have really bad dimming. i mean if you look at all the red coming off the battery and there is this single skimpy black wire that should sound the sirens right there. plus it only costs about 5 bucks for wire if you dont have it laying around allready.
G20 Stereo system ipgrade problems...whats with all the damn harnesses?!? jarnld Audio/Security 0 06-05-2005 12:34 AM
Gotta Tech question (Triple cat-back what does mean for my SpecV) babyskyline Sentra | 200SX (USDM FWD) 4 03-31-2005 11:26 AM
have ? about what to get for a new aftermarket stereo system as in what do i need! Probegt/civic Interior | Audio | Security 2 09-27-2004 11:22 AM
Does the monsoon stereo have pre-outs??? for amplifiers? Smoknbarrels Jetta/Vento/Bora 1 08-30-2004 12:24 PM
Direct Power System-What does it really do? aehaas Murciélago (Murcielago) 4 11-27-2003 09:36 PM
