engine light
2001 se 3.1 liter aprox 90,000 miles. I am getting a code 420. I have recently replaced the catalitic convertor (which was almost completly plugged) changed the plugs and wires. I have checked for vacuum leaks and found none. The code was reset several times and still comes back. Any ideas?
Re: engine light
![]() Thrasher CAI, DHP v1.0 ECU, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS,TB spacer, MSD 8.5mm wires, Autolite 104 spark plugs, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
Re: Re: engine light
'99 SE (l36) 125k mi. FWI | ZZP HVTB St. 1 | WP UD Pulley | 3" DP/HF Cat/U-bend Del.
Re: Re: Re: engine light
![]() But he's fortunate its only a pending code and the car will run for days on end although the SES light would be a nag. Might lose about 1 - 2 mpg in the process. ![]() Thrasher CAI, DHP v1.0 ECU, 3.25 SC pulley, CAIT GMAF, Hi-Flow CAT, u-bend delete, 160 TS,TB spacer, MSD 8.5mm wires, Autolite 104 spark plugs, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
