Old 06-17-2005, 11:07 AM
Damienh Damienh is offline
Send a message via AIM to Damienh
B16a bucks when i drive it
With a 1990 automatic integra ecu my car runs fine as soon as i hook up the obdo B16a ecu my car will buck when it moves and when it isnt moving and i hold it at like 3 grand it dies down and then fires back up. I put the integra ecu back in and it runs fine. could it be from the ecu because i have and obd1 motor ini the car will i need and obd1 ecu and jumper harness. Whats my problem with the bucking.
Old 06-17-2005, 11:32 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: B16a bucks when i drive it
which distributor and injectors are you using?
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-17-2005, 05:25 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Well since the teg ECU is OBD0 you can rule that out... Its gotta be something that B16 ECU... Is your car an auto? And what numbers does the B16 ECU have on it? Theres 2 different kinds that come with those PW0 and PR3s (I think), and then theres auto and 5 speed...
Old 06-17-2005, 07:12 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
yea, we need more info whether ur cars stick or auto etc etc
