Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-17-2005, 10:09 AM
loco69boyz loco69boyz is offline
Leaking tranny oil. HELP!!!
Does anyone know what could be the problem if transmission oil is leaking from the axle on the pass. side. It comes out where the axle is connected to the tranny(H22a). I replaced the transmission axle seal and its still leaking. Anyone know what could be the problem?
Old 07-01-2005, 10:32 PM
bobinohio84's Avatar
bobinohio84 bobinohio84 is offline
Send a message via Yahoo to bobinohio84
goodness that's bad. Have you checked to see if ur axle has any "serious" damage to it? Cuz if it did that might explain it... And when did this start? Did u do something to it then it started or was it just "out of the blue"?
My car is my baby. Her name is Bridgette.
Old 07-02-2005, 12:12 AM
92_prelude_si's Avatar
92_prelude_si 92_prelude_si is offline
Re: Leaking tranny oil. HELP!!!
Did you replace the o-ring that goes on the axle
Old 07-03-2005, 06:36 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
That was happening to me, the shop replaced both front axles, balljoint boot, and the output shaft seals. This could be your problem. So you know, this was a pretty cheap fix for me, the whole thing with labor only cost me $247.06.
Old 07-05-2005, 12:43 PM
It just started happening. I had the transmission axle seal replaced but its still leaking. I notice that the axle on the p. side slides out some like a half an inch after i drive it around. Then after i drive around i can push the axle into the transmission some. After i do that it stops leaking until i drive it again.
