Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-17-2005, 07:09 AM
Peacefrog Peacefrog is offline
Thumbs down 95 Cutlass - front end vibration
Hi, my cutlass has a major problem with the front in vibrating. It is getting worse [not to mention it has 280,000miles on it] But is this serious? I have had 3 mechanics look at it, did the aligment, balance of wheels, changes the tire rods [you know what I mean] and yet this vibration will not go away. I drive interstate mostly [75mph] and roads and not great so it feels worse than I think it is. Is there anything else I need to have looked at. Oh, I guess I need to mention that in Feb I had an aligment done and 4,000 miles later one tire was loose to where only 1 lug nut was holding it on. Talk about livid!!!! Did this cause the problem that I have NOW? HELP, very distressed over this.
Old 06-17-2005, 10:02 AM
SupremeCutlass's Avatar
SupremeCutlass SupremeCutlass is offline
How long has it been since you've had your suspension/shocks looked at?
Old 06-17-2005, 10:41 AM
Re: 95 Cutlass - front end vibration
Good question? They were replaced in 2001 or 2002 I believe.
Old 06-17-2005, 11:46 PM
well, just to be sure, push down on the front end and if it only comes back up once, you're all set. I'll try and look into it a bit and see what I can find. What kind of vibration is this? try do describe it a little more please
Old 06-18-2005, 05:23 AM
I actually went to ANOTHER garage across town yesterday and the mechanic drove the car and told me it felt like the tire. Either it was worn or out of balance. He also told me that the vibration was intensified because my hood is loose, not bad just wiggles more than it should.
So I went to my tire place and asked them to balance the front. Sure enough that corrected the major problem. The front driver tire had a weight not completely secure. Needless to say it is very sad that when a WOMAN takes a car to a garge it is never serviced in the same way as when a man takes it in. It's a shame.
I did tell the mechanic to check the suspension and he said it was fine.
Thank you for your help.
