97 Trunk Leak
I seem to have water coming into my trunk when driving,I looked for leaks and can find none.I sealed around the rear window to be sure and the water is still coming into the trunk.Is anyone else dealing with the same issue ?? I cannot find the source of the leak,it does not leak while parked only while driving.
hi , did you take every thing out the trunk and check for any cracks,or see if the rubber is in good condetion.
Re: 97 Trunk Leak
What color is the water in your trunk. Clean water is usually a water leak from above and dirty water is a water leak from below. Since you only have a leak while driving I would remove everything from the trunk and check the seams while looking for water stains.
Take your garden hose and gently spray underneath the car sections at a time watching for water entering the trunk. once you locate where the water is coming from you can seal it.
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
