what times sould i be running?
Well this isnt the most correct question, but im just wondering around what 1/4 times do u guys think im running(we dont have a track here) i have a 91 CRX SI, it has a sohc ZC swap, bullfrog stage 1 cam, intake, cat-back exhaust, and a mugan chip that takes away the redline, so im shifting at 8,000rpm's, ive only raced 2 times, once againts a new mazda 3(and yes there fast 2.3 dohc, 168 hp) and i beat him by a full car, then aginst a 2003 honda civic Si with intake, headers, exhaust, and i beat him by a car and a half....so what do u think i should be running? thanks!
~james |
Re: what times sould i be running?
15s... those other cars you mentioned are heavy and the drivers may suck...
2008 KIA Spectra5 SX 2010 Honda CR-V EX |
high 14's low 15's
Re: Re: what times sould i be running?
the one that drives the 2003 SI, is a realllllly freaken good driver, hes been racing all his life, that si is his daily drivier, he has another si (2000) and he has track times of it running a 12.2 all motor lolz |
you're reving your stock d16a6 with a cam to 8k? You're an idiot. Did you even upgrade the valve springs and retainers? Do you thikn the main bearings can handle that? Cause I sure as hell dont. Have fun rolling a bearing or floating a valve.
But yeah, you should be running low 15s.
Saturn Stealership Technician #331 |
I know he is gonna respond by saying he has a swap so talonpunk a sohc zc is a d16a6 basically.
***90 Civic EX 4 Door*** ![]() Quote:
without an upgraded valve train you will have problems with the valves opening and closing correctly called VALVE FLOAT. they may either stay open or closed or open half way. you may not have those problems yet, but it is a big possibility....a "chipped" ecu means nothing when dealing with valve springs and retainers... your "chipped" ecu advanced the timing curve, adjusted the idle, and fuel pressure, maybe the redline correct?? and lighter retainers such as stainless or titanium will allow you to also rev faster and safer in conjuction with new stiffer valve springs. just an idea to look into. the parts must all work together to obtain the most and safest amount of power.
Back to the question...there are too many variables to guess..... sea level, heat, tracking, track conditions, rt, and mostly driver. i would hope for low 15's but expect mid 15's. your ecu may allow you to rev high, but can your engine take high revs?
They say "speed kills drive a Honda" I say "You're right" "I'm a kid with a grown man's mind turning corrupt" Wu Syndicate |
He's just another kid that see's a "Chipped ECU" on ebay that allows his car to rev to 8K, and thinks thats all he needs. Hopefully he'll learn.
dSoc member #67 1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook: 1994 Honda del Sol EG1 S-full VTEC conversion. Buy my Del Sol parts!! |
no doubt, but his car and he can either choose to take or ignore our advice. either way i don't care.
eh i say low 16's, very high 15's at best....there's too many variables when street racing for it to be an accurate race..... and btw its pointless revving to 8k on that d16, by that time all your doing is making lots of noise, with NO power gain at all.....
hes got a bullfrog cam so its probably making power up there, maybe starts to stop around 7700ish but still I heard lots of good about that cam. but either way, that motor can't handle 8k revs on stock internals. I guess that ECU also upgraded all your bearings too huh? Damn I need to get me one of them so I can rev my dohc to 10k. I mean seriously, do you know ANYTHING about the internals of a motor and how they work? That motor was NOT meant to rev to 8k from factory. You're an idiot, have fun when you loose oil pressure and roll a bearing, or better yet, throw a rod.
cause I hate when people dont drive their car right to set up they have.
