Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 06-17-2005, 12:21 AM
Red B16A's Avatar
Red B16A Red B16A is offline
Exclamation Better Handling
I've got some tokico illumina shocks all around with a Type R fornt strut and Tenzo R rear strut, and I ve got some crapy APC adjustible coil overs with no lower sway bars(front or back). All on a 95 civic hatch, and I really want to get this baby a little better. I set the front shocks to 4 setting and rear to 3. The rear is nice and stiff, one of the wheels always comes off the floor when pulling into driveways.
95 JDM B16A Hatch DX
Stage 2 Zex Cams
comp cams 913 springs and retainers
professional products intake mani
68mm throttle body
ZR racing header
Handata s200
Password JDM intake
Old 06-17-2005, 01:24 AM
BullShifter's Avatar
Re: Better Handling
Strut bars . . .
First get rid of the junk springs. Get some H&R springs from Tire Rack. After that, get an alignment and camber kits if needed depending on the drop.
If you have shitty tires, that's a good place to work on.
Get a stock front sway bar with poly bushings and a larger aftermarket rear bar. Sway bars, especially the rear one with make a huge difference.
Set the rear struts stiffer than the front.
Old 12-27-2005, 12:01 AM
Red B16A's Avatar
Re: Better Handling
Should I go with the race or sport springs
Stage 2 Zex Cams
68mm throttle body
ZR racing header
Handata s200
Password JDM intake
Old 12-27-2005, 09:59 PM
eurobeaner's Avatar
eurobeaner eurobeaner is offline
Send a message via MSN to eurobeaner
Re: Better Handling
SPORT! i got them, they are very nice... not too bumpy, great handling, and not too much of a drop to cause you to buy camber kits... i also have a 95 civic, the handling is very thight now, all i need is new struts and sway bars
if you do the race springs they will be very bumpy and uncomfortable... unless your RACING!!, you will also need a camber kit with it.. so if its a ROAD (aka daily driver) get the sport... just my thought
95 Civic EX
H&R sport springs
KYB AGX Struts
Energy Suspension Poly Bushings
15" black VSR's on nitto NT450 not-so extreme performance 205/50/15
CAI
http://www.cardomain.com/ride/2489240/1
Old 12-27-2005, 10:04 PM
Re: Re: Better Handling
amen to that.
