Old 06-16-2005, 11:02 PM
cf1 cf1 is offline
how to adjust valve lash
instaling new cam and roler lifters in 93 chevy full size pu 4.3... how do i adjust the back lasch on the rockers?
Old 06-20-2005, 02:18 AM
tirefryer93 tirefryer93 is offline
Re: how to adjust valve lash
Don't take this the wrong way, but make sure your cam is a hydraulic roller cam. As far as back lash, roller lifters are probably different from standard hydraulic lifters. I guess I've never messed with rollers.
Old 06-22-2005, 10:59 AM
cf1 cf1 is offline
Re: Re: how to adjust valve lash
tirefryer93.. wich is the exhaust valve and which is the intake valve on 4'3. i found how to adjust the lash but it dont show which is which..
Old 06-26-2005, 09:36 AM
bracketshark bracketshark is offline
Re: Re: Re: how to adjust valve lash
The exhaust valves line up with the exhaust maifold openings, and the intake valve lines up with its corresponding intake runner. You might want to get someone familiar with a engine to do this work. Just my .02 worth.
Old 06-26-2005, 10:43 PM
cf1 cf1 is offline
thanks for the answer, i went by the haynes book.i must have goten it right this engine cranked right over the lifters are a little noisy, but when the cam breaks in i will tighten them down again, i put a comp cam in its a little over but should give me more tork.. thanks
