Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 06-16-2005, 10:27 PM
Timothy A. Timothy A. is offline
Unhappy 93 Dakota intermitent restart problem
93 Dakota 5 Speed, 3.9, Multi port injection, 120,000 miles
Intermitent restart problems mostly in hot weather. Engine never stops running once started only problem is when trying to restart. Truck fine for months at a time then once and awhile will not start after stoping. You can wait a few minnites then will start and then again not. Sometimes no spark and sometimes no fuel to engine. Like i said never stops while running only when trying to restart very random problem.
I have replaced Fuel pump, All plug wires, Rotor and cap, Plugs, Fuel filter ,Computer. Problem still haunts me for two years. Problem showes up more in hot weather. Thanks for any information
Addition: I have relpaced crankshaft position sensor but still have the same starting problem described above.
Old 06-17-2005, 01:48 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 93 Dakota intermitent restart problem
you could have a bad crankshaft position sensor, mounted in your bellhousing on the passenger side of the transmission.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 06-19-2005, 02:33 PM
I have replaced crankshaft postion sensor still have same intermittant starting problem. It starts early morning and at night the rest of the time here in AZ it is 110 degrees once started even in this heat runs great no problem till try to reastart
Old 06-21-2005, 11:43 PM
or possibly a bad ASD relay.
Old 05-13-2006, 03:17 PM
cresults cresults is offline
I have been experiencing the same problem with my 93 Dakota.
Did you ever resolve the problem?
Old 06-06-2006, 10:24 AM
89ltd 89ltd is offline
I can't find my manual on that right now but does the 93 have a distributor? Is there a pickup coil in that ignition? If not, I would say cam sensor,
Old 06-06-2006, 05:56 PM
Have replaced the ditributor cap, rotor, plugs, plug wires, coil, fuel pump, fuel filter - still same problem as Timothy described in his original posting.
Old 06-07-2006, 03:02 AM
I'm not talking about the ignition coil, but the hall effect pickup coil in the distributor under the rotor.
Old 06-07-2006, 09:53 AM
looks like this
http://catservices.wrencheadpro.com/...e/KEM/e125.jpg
Old 06-20-2007, 04:25 PM
WarHawk1974 WarHawk1974 is offline
I have the same problem..however I get good spark, can dump a bit of fuel in the throttlebody and it will fire right up, but cant hear the fuel pump whine when to pre-pressurize the fuel line, I know the fuel pump works
Can the fuel relay get old or go bad after time? I have switched relays out in the box in the engine well...but it still wont work, sometimes it does, sometimes it wont, but once it works it works fine and will stay running no problems
Oh yah..I have a '92 Dakota with the 5.2L 318V8
