Old 06-16-2005, 10:35 PM
Zachp911's Avatar
Zachp911 Zachp911 is offline
Question on touch-up painting
I know this should be posted in the "Car Detailing" part of the forum, but nobody ever answers back in there.
So heres the thing... the scratch on my car is down to bare plastic. Do I need to put a few coats of Primer on the scratch before applying the touch-up paint? And after I apply touch-up paint, I need to compound it out, correct?
One more thing, what kind of paint does the Prelude use? Acrylic or Anamel? I have a Premium White Prelude, (Paint Code --> NH624P). I'm open to any tips and suggestions.
2008 BMW 335i
Old 06-16-2005, 11:03 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Question on touch-up painting
Sand the area, using 360 grit, wet sanding.. then work your self up to 1000 grit paper. Apply several light coats of LAQUER Dupli Color Filler Primer, then apply several coats of the touch up paint. After that apply several coats of laquer clear coat. Use 1500 grit wet sanding, then apply 3M Rubbing Compound, and apply wax (I prefer Mothers..)
I think the paint most car companies use is enamel, could be wrong though.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 06-17-2005, 08:21 AM
Zachp911's Avatar
Thanks for the help. I read somewhere though that you shouldnt wax the car for 2-3 weeks after touching-up a scratch??
2008 BMW 335i
Old 06-17-2005, 09:44 AM
Cyprus106 Cyprus106 is offline
Send a message via AIM to Cyprus106
I read somewhere that the U.S. military are flying planes across the sky in criss-cross formations high in the atmosphere, spraying deadly chemicals and gasses that block out the sun into major ciities and densely populated areas. Of course, every meteorologist and weatherman in the country is secretly in this evil plot.
Hung by a halo or stabbed by horns, sad to say; they're both the same
Old 06-17-2005, 10:13 AM
Zachp911's Avatar
Re: Re: Question on touch-up painting
2008 BMW 335i
Old 06-17-2005, 11:55 AM
IIwhitexb0iII's Avatar
IIwhitexb0iII IIwhitexb0iII is offline
Send a message via AIM to IIwhitexb0iII
Re: Re: Re: Question on touch-up painting
Originally Posted by ludespeed501
you cannot necessarily believe everything you read is all he was trying to say.
Old 06-17-2005, 03:00 PM
rofl!
Old 06-17-2005, 05:26 PM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
You think? I am pretty sure they use Acrylic, cheaper, easier to paint without the harmful gasses. Doesn't last as long though. A very simple way to find out what paint your car is painted in, is to wait for a fairly hot day, then find somewhere on your paintjob where no one will see too easily (like in the door sill or something) and press your fingernail against the paint. Acrylic will soften up and let your fingernail dig in.
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
