Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 06-16-2005, 07:28 PM
bronxblaza117 bronxblaza117 is offline
Send a message via AIM to bronxblaza117
front tires wearing fast then back...
the front tires on my 1999 Honda CRV is wearing out alot quicker then my back ones... to fix this i just get my tires rotated right? cant i do this myself, just take the front ones off and put em in the back and vice versa?
Old 06-16-2005, 11:37 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: front tires wearing fast then back...
Yes, that would prolong the life of your set. Heavy FWD Vehicles especially small SUV's and Minivans wear out their front tires much faster than their wears. For balance reasons, its usually a good idea to keep the Lefts on the left and the Rights on the right too.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 06-17-2005, 01:04 PM
but mine all wheel drive
Old 06-17-2005, 06:22 PM
slideways...'s Avatar
slideways... slideways... is offline
still, if all the wheels drive the car, only the front ones steer. this alone will put more wear on the front than the back. AWD vehicles are made to grossly understeer from the factory as a safety precaution. this means that the front tires are designed to have less traction than the back ones to keep your back end behind you where it belongs. this makes for more wear on the front.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 06-17-2005, 06:31 PM
oh ok... so i went to getem rotated but the guy at goodyear said i should jus replace them because they have cracks all over the place... i thought those cracks were normal and not a big deal? the cracks were on the tire itself, not on the sidwall or anything... wat u thing?
Old 06-17-2005, 06:47 PM
depends on whether those cracks are part of the tread or not
this is tread
every tire has a different pattern, but they are all a Pattern so if there are extra cracks then its bad
Old 06-17-2005, 07:45 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
ya cracks that arent tread is dry rot... not good, it weakens the integrity of the tire and can cause a blow out.
Old 06-17-2005, 07:55 PM
oh ok...yea im not talkin about the treads, im talkin about in between the treads...im gonna change em as soon as possible
Old 06-17-2005, 10:11 PM
drdisque's Avatar
also, the way AWD CRV's are set up, the Front wheels primarily drive the car unless one of them slips, then torque is sent to the rear wheels.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 06-17-2005, 10:32 PM
yeah i thought that was how it worked also, but i wasnt sure so i didnt want to say anything
Old 06-18-2005, 02:09 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Normally the outer edge of the front tires always wear more than the rears. Proper inflation will help to minimize this tendency but not eliminate it. Regular rotation will help to balance out this effect by spreading it across all four tires. Not taking corners so fast will help even more. I've had tires with 8X,XXX miles that were worn pretty much even all the way across.
Mark's Garage est. 1983
