Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-16-2005, 07:28 PM
RSLaser RSLaser is offline
Torn Boot
Alright a new problem emerges right befor im about to leave for school...the driver side cv joint cover is torn. Now i have a couple questions here. How would a boot just tear or would it even? When i am driving i hear a slight clicking noise, that when i put it in 5th at about 50 and try to accelerate i can hear it a little louder and longer.
Is the CV joint shot...or is it just the boot tore and now i can hear it? Or does it mean its about to go bad?
~Thx Matt
1991 Plymouth Laser RS
Only sat for a few years....
Old 06-17-2005, 09:59 PM
macder macder is offline
Send a message via MSN to macder
Re: Torn Boot
The boot is there to keep the grease in the joint and keep dirt out. When it tears, stuff like rain, snow, etc... wash away the grease quicker then you think. Your cv joint will also get contaminated with road dirt. If you don't change the boot in time it will screw up your cv joint. I suggest you replace the boot ASAP before causing more damage. In the mean time, you should grease up your cv joint.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 06-19-2005, 12:50 AM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
You sure its the boot? Is the sound all the time or just when you turn?
On front wheel drive cars like ours the boot just starts to crack over time and then eventually tears and then pop there ya go. I wouldnt wait too long to replace it.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
