| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
help me out pleaaaase
Alright, i have a 1985 chevy silverado 4x4 it came with a 305 and the 700r4 tranny, i swapped the motor with a higher performance 350, i have the dart lightning heads with i believe a 9:1 compression ratio, a .450 lift .460 on duration cam, the crank was milled at the usual rebuild measure, a hundred thousands i think, and the block was bored .30 over, i have the stock quadrajet carb but it was rebuilt and i was told by the guy who did it that he tried to make it a little more hot rod to fit my motors specs, and his name is a pretty good one in my town for carb rebuilds, so i figure its rebuilt right, but when it came to getting my motor to run we had to put a new spring kit on my distributor and the carb was funny on adjustment, and the timing was a pain, but after was all said and done it ran pretty good, but now it has this thing it likes to do where it will run really smooth but randomly it will act like its bogging down when you hit the gas and the truck will shake more than usual when accelerating...what can i do to make this go away? i was told it could be a peice of trash in my carb, but im not too sure on that, i was also told my float could need readjustment but i just dont know.......id like some instruction on some things i could try and do....i know my way around a motor compartment ok so anything would help thanks.......Red
Re: help me out pleaaaase
What octane gas are you running?
I have a 1999 f150 XLT reg. cab with a loose wire at the wiper, turn signal switch. All the wires (7) have come loose from one connection block (7 wires) and I need the color code and placement of the wires so I put them back in the connection block>
I have a 1999 F150 XLT reg. cab with loose wires at the wiper, turn signal switch. I need to know the wire color code and wire placement in the connector block for the switch.
Re: Re: help me out pleaaaase
Hey Buddy... Start your own thread for that problem..lol |
Re: Re: Re: help me out pleaaaase
