Old 06-16-2005, 04:48 PM
turbo93impreza turbo93impreza is offline
how much power from the stock turbos? td04-09b
i'm considering using td04-09b's in a non-3000gt related preject and while researching them i found out that they are used in the 3000gt.
what is the most horsepower you can get from the stock turbos? (with all the right upgrades, fmic, injectors, etc)
how many psi can they handle before they blow hot air?
would anyone be interested in trading theirs for a pair of subaru td04-13t's?
thanks in advance guys
Old 06-16-2005, 08:00 PM
Hotshot8792 Hotshot8792 is offline
Re: how much power from the stock turbos? td04-09b
all depends on what car your putting them in and what kind of set up your using.
On a Twin Turbo set up in a 3.0L v6, they are capable of holding around 10 psi to redline and around 15 psi before dumping in hot air. On a car with a smaller engine and less cylinders, they would be able to hold more boost because there is less volume to fill up. On a bigger engine, it would be lower.
If your doing a single turbo set up with one of our stock turbos, you'll probably want to think about another turbo choice, unless your trying to turbocharge a weed-eater.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-16-2005, 11:20 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Lol
Old 06-17-2005, 04:16 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
also, lots of people want the wrx 13t's, just go to www.3si.org and as the same question.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
