Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-16-2005, 03:57 PM
jn316n_e_qstns jn316n_e_qstns is offline
serpentine belt
How do you take off old serpentine belt to put on new one on 95 bonneville?
Old 06-17-2005, 01:01 PM
_Louie_ _Louie_ is offline
Re: serpentine belt
You will need to remove the lower right engine mount (facing the front of the engine). It can be accessed thru the pass side wheelwell. Pull back the shield at the bottom of the wheelwell and you will see the hole to access the stud. When I removed mine, the stud and all came out (not just the nut on the stud). It was actually easier that way. Knock out the spacer and then you can replace the belt.
