Old 06-16-2005, 03:02 PM
brenscars brenscars is offline
buying 1988 Honda Civic
I am considering buying an 88 Civic Hatchback. The story goes that the car has been sitting two years. The woman that has it stopped driving it when she heard a weird noise from the wheels(wheel bearing/axle). Said she got scared. Anyway I am just wonderiing if anybody has any advice about what it might be? Also, since that car has been sitting so long what would you put in the crankcase to avoid a very dry start if and when I try to fire it up? She said that car ran fine when she stopped driving it. Thank's.
Old 06-16-2005, 04:20 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: buying 1988 Honda Civic
just remove the spark plug wires and turn the engine over a few times. thatll lube it up good and the car wont start that way.
id recommend changing the oil first though.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-17-2005, 12:20 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
the noise might be the CV joints.
Old 06-21-2005, 07:09 AM
Riceboy891's Avatar
Riceboy891 Riceboy891 is offline
It could be the cv's but the wheel bearings would explain it too. They make a loud humming sound when they are bad. Usually when cvs go bad you hear clicks when turning. It could also be a bad alignment and the wheels are making noise rubbing the road funny.
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
KYB AGX Shocks/Tein Springs
"yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber
