Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 06-16-2005, 12:51 PM
jono828 jono828 is offline
suggestions
I have a aem cai in my 94 si. Im puttin a spec stage 1 clutch in my car next week. I have plans of putting a greddy evo exhaust and stainless steel greddy headers. Besides that, Im not sure what i want to do. Any suggestions in terms of engine work besides forced induction, I wanna keep my car naturally aspirated.
Old 06-16-2005, 01:39 PM
Gohan Ryu Gohan Ryu is offline
Since you're doing your clutch you should get a lightweight flywheel at the same time. Pulleys are a good idea, some people don't like aftermarket crank pulleys but I haven't had any trouble with mine. Cam gears to help with the tuning. Stage 1 cam (I wouldn't recommend stage 2 for street use). Titanium valve spring retainers and stiffer valve springs so you don't float the valves - maybe a fuel pump or rails for better throttle response. ECU or a Hondata...these are the reasons why us tuners are always broke.
Old 06-16-2005, 06:07 PM
Zachp911's Avatar
Zachp911 Zachp911 is offline
Re: suggestions
High-Flow Cat, Intake Manifold
2008 BMW 335i
Old 06-17-2005, 11:23 AM
if i were gettin cam gears, do i have to get the ecu tuned for the change w/ the new cam gears?
Old 06-17-2005, 01:09 PM
Re: suggestions
You don't have to, but it would help to upgrade the ECU or chip it. But like I said earlier since you are installing a clutch and you're going to have the tranny out, you should do the flywheel at the same time.
Old 06-17-2005, 06:20 PM
i kno i should get a lightweight flywheel but i have heard that the rpms dropm off really quickly when there is a lightweight flywheel. Is that true? And has anyone heard anything about spec clutches?
Old 06-17-2005, 08:12 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Re: suggestions
Thats the point of a lightweight flywheel. It increases reponse, and allows the RPMs to drop quickly allowing faster shifts.
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 06-18-2005, 12:40 AM
During downshifting, rpms can drop off very quickly if u have a lightweight flywheel. i live near new york city and im in a lot of stop and go traffic i dont wanna be concerned about
Old 06-19-2005, 11:41 AM
Zachp911's Avatar
Re: suggestions
I heard somewhere that cam gears are pointless unless you have an aftermarket camshaft.
2008 BMW 335i
Old 06-20-2005, 01:33 AM
92_prelude_si's Avatar
92_prelude_si 92_prelude_si is offline
Re: suggestions
I too am installing a stage one clutch but where can we find a not so pricey flywheel?
Old 06-20-2005, 09:56 AM
Re: suggestions
You can keep the RPMs up between shifts with the throttle - just don't let up completely on the accelerator while shifting. Keep the RPMs between 2500-3500 between shifts when you're just cruising, or if you're racing don't let the RPMs fall below 4500-5000. It takes practice to do it smoothly and it helps to have a short-shift kit.
With good throttle and clutch control I can shift into the next gear without dropping any RPMs, whether I am racing or just cruising. I've never heard of anyone who un-installed a lightweight flywheel because they didn't like it - it makes your car extremely responsive to the accelerator.
Old 06-20-2005, 04:58 PM
thanks for the replies. Im still debating whether im gonna do. I kno i should but it all rests on how much money i have.
Old 07-09-2005, 05:25 PM
http://www.horsepowerfreaks.com/pric...eels/Flywheels
There are some reasonably priced flywheels from this website
