Old 06-16-2005, 12:44 PM
jlshondacrx90 jlshondacrx90 is offline
how do you reset ECU?
i was jsut wondering on how you reset the ECU? do you just unhook the negative terminal on your battery?
Old 06-16-2005, 01:48 PM
steve-o317 steve-o317 is offline
Send a message via AIM to steve-o317
yup thats what i do take off the neg battery cable for like 20sec-1 min works fine. i also think you can pull a fuse under your hood might be the hazard flasher fuse not 100% sure though
89 std hatch back
D15B1 4 speed
MPFI Swap
CAI/4-2-1 Header/soon to come custom 2 1/4" cat back
NEW!! 15" rota slipstreams flat black with 205/50/15 falken ziex ze 512's
Old 06-16-2005, 02:34 PM
dagoEF's Avatar
dagoEF dagoEF is offline
Re: how do you reset ECU?
Pull the ECU fuse under the hood instead of disconnecting the battery, the hazard fuse just clears the ECU codes, do that after you fix you problem.
Old 06-16-2005, 10:17 PM
Hondacrx6455 Hondacrx6455 is offline
which one is the hazard fuse?
Old 06-16-2005, 10:30 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
i disconnect neg term, then pull ecu fuse.. put fuse back in after a min and reconnect neg term
Old 06-17-2005, 12:12 AM
dagoEF's Avatar
the hazard fuse is in the fuse box under the hood,should be the one closest to the fender, the 10amp one.
Old 06-18-2005, 01:45 AM
arodg25's Avatar
arodg25 arodg25 is offline
What you should do is get your car to normal operating temp. then pull the ecu fuse(so you dont lose your radio stations) for like a minute or two. and then start your car without touching the gas pedal, just turn the key, and let it idle for like 4-5 min. shut it off and turn it on again and your ecu is reprogramed to give you the best mileage. you should also do this anytime you add anything like I.H.E. etc...
Old 06-18-2005, 02:23 AM
BullShifter's Avatar
That is the proper way
