Old 06-16-2005, 12:16 PM
lange1191 lange1191 is offline
blower motor
I have a 99 cherokee I just replaced the blower motor, but now when I try to turn it on it only works on high. What could be the problem.
Old 06-16-2005, 03:18 PM
avmx avmx is offline
I would test the switch and check if there's a blower motor resistor in the circuit. If the resistor goes bad the blower will only operate in some settings.
Old 06-16-2005, 03:51 PM
I already checked the resistor and that wasn't it. Is there anything else it could be.
Old 06-17-2005, 11:37 AM
Re: blower motor
Old 06-18-2005, 11:31 AM
Saudade's Avatar
Saudade Saudade is offline
Re: blower motor
The resistor provides a ground path for the blower. Sounds like you may have pinched the blower wires when you replaced it and it's grounding out directly.
