Old 06-16-2005, 12:03 PM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
Question swap
okay i have a crx dx and im trying to swap in the d16a6.. problem is i dont have an engine hoist... is there another way of going to pull the motor out?? and putting the new one in?? and the wiring can i just do dx to si conversion... just like the dpfi to mpfi swap conversion harness?? need help if you can i would really appreciate it... please dont burn on me...
Old 06-16-2005, 12:15 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: swap
If you have 2.25 ton or bigger jacks, you might can raise your car up, unbolt the engine and tranny, remove the axles and drop it down, and put new engine in the same way... or you can ghetto rig a chain around the engine over a thick tree branch and pull it that way (not recommended)...
As for MPFI, as long as you can figure out what wires go where and what needs to be de-pinned and re-pinned to the ECU, you can do it. If you suck at wiring, then you can pay for some sort of conversion but you still have to repin it at the ECU. Remember to use a PM6 ecu and distributor or it won't work. GL
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-16-2005, 05:11 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: swap
rent an engine hoist, its like 30 buck a day.
Old 06-16-2005, 10:40 PM
Re: swap
u see its cheap and all to rent a hoist but a guy with no job... i dont kno lol...
Old 06-17-2005, 10:52 AM
Kind of a Big Deal
Re: swap
well that sucks, i suggest getting one, cuz youll need it if you plan on modding your car...lol
Old 06-17-2005, 05:14 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Re: swap
Bro, if u currently have no job, dont pull that engine out! Because I can almost gaurantee you, you will have to buy a lot of 'little things' for any swap, and those little things add up...
But I did hear that some people take off the lower cross member and take the engine in and out that way... Downside is u have to jack the car up pretty damn high even with the cross member out of the way...
