Go Back   Automotive Forums Car Chat > Buick > Century
Old 06-16-2005, 08:23 AM
jwichman jwichman is offline
2000 Century HVAC Problem
The MAX, VENT, BI-LEVEL, HEAT, BLEND, DEFROST selector switch quit working yesterday. The AC still works when the button is pushed. No matter where the selector switch air is blown out under the dash, the dash vents and at the defrost windsheild locations all at the same time. The MAX AC recirculation damper does not open either. Anyone experience this before? What was the fix? Any other suggestions?
Thanks,
Old 06-20-2005, 11:19 AM
sellncars's Avatar
sellncars sellncars is offline
Send a message via AIM to sellncars Send a message via Yahoo to sellncars
Re: 2000 Century HVAC Problem
Sounds to me like a vacuum line came off under the dash, more then likely. Your going to have hunt around under there for a vacuum line that is loose or broken.
Good luck,
Sellncars
Thanks,
1999 Chevy Malibu, 3100V6 VIN J with 73,000.
1997 GMC K1500 EXT cab, 350 Vortec with 164,000
Old 06-20-2005, 03:37 PM
Re: Re: 2000 Century HVAC Problem
Yes I have nosed around both under the dash and under the hood. One would think that you would be able to hear a vacuum leak, especially under the dash. No such luck. I will have to do some additional more in depth looking I guess.
Good luck,
Sellncars
