Old 04-18-2002, 03:38 PM
nijia555 nijia555 is offline
tire chirping???
i have some yokohamas on my stock 14 inch wheels, when i make turns at like lets say 20mph i hear chirping, you know like i am going hella fast or something, does this mean that my wheels are sliding or does it mean that they are sticking. I dont really feel anything different, but i dont want to be surprised someday if i spin out in the middle of the road or something.
the happy civic sedan with custom catback w/ es oval.. new clutch needed
Old 04-18-2002, 04:38 PM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
it means they're slipping. good grip makes no noise.
if your car is lowered, get it aligned. the camber is probably what's causing the problem.
if it's aligned properly, then it's the tyres. yokohamas are considered good tyres only in the states.
Old 04-18-2002, 11:46 PM
my car is not lowered, could you recommend some tires that i could look at the next time i am out for the purchase.
Old 04-19-2002, 12:04 AM
CivicEx95's Avatar
CivicEx95 CivicEx95 is offline
Banned
Send a message via ICQ to CivicEx95 Send a message via AIM to CivicEx95
It's going to be an alignment problem. My tires did the same thing, but it was after its lowered. You go around a soft turn slow, and it was squealing because the toe was off. Get it fixed ASAP, cause incorrect toe will eat your tires quick
Old 04-19-2002, 01:40 PM
Mirt3 Mirt3 is offline
Send a message via AIM to Mirt3
check yer tire pressure. that would be my first guess and easiest to fix. if they are low, they squeal real easily. peace
-Mike
Winter tires - speed rating & downsizing Hello: A couple of questions for the forum. I have an 07 Camry LE. I am buying winter tires for her. I am jtmann Tires and Wheels 3 11-18-2010 09:07 AM
gas mileage decreased with new tires?? Dolphingrrl23 General Discussion 5 08-21-2009 04:01 AM
Issues with squeaking tires. Zandra Cavalier Problem Diagnosis 1 07-29-2009 05:06 PM
Tires for 15 x 10 Rims? z4teen Tires and Wheels 1 06-03-2009 08:29 AM
Tire pressure. sailor86 Engineering/ Technical 26 03-18-2009 04:44 PM
