Old 06-16-2005, 12:56 AM
x8xViperx6x's Avatar
x8xViperx6x x8xViperx6x is offline
Send a message via AIM to x8xViperx6x Send a message via Yahoo to x8xViperx6x
sqeeky brakes...
I just recently changes the pads on my 93 maro and they are still sqeeky.. i just bought some anti-sqeek spray, gunna try that. Also when I brake hard (well harder than normal) my rotors sound like they are vibrating.. any one know why? (Sounds like they arent supposed to do that)
1993 v6 3.4L
Old 06-16-2005, 01:14 AM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: sqeeky brakes...
How long ago did you change them, you say you changed them recently but then you say they are still sqeeking meaning they have been doing it for a while... They will usually do that for a day or two depending on how much you use them but it should go away after a while. About the vibrations go back and check all the shit you took apart and make sure everything is torqued right.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 06-16-2005, 02:14 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
when you did your brakes, did you rough them up first? take a peice of sand paper and lightly scuff the rotor surface and the pad and put it all together. Also something most people dont do is give the brakes a propor break in time of about 100 miles. if you put brand new parts on, and then go out and use them heavily, the pads will "glaze". but the vibration you are talkin about sounds like warped rotors to me.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 06-16-2005, 09:00 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
most ppl don't recommend changing pads and not either replacing, or having the rotors turned.
Old 06-17-2005, 02:19 PM
LT1MAN LT1MAN is offline
Banned
you need to buy acdelco pads, cheap pads will always squeak no matter what you put on them, and the vibration means you need your rotors turned or replaced.
