Old 06-16-2005, 12:09 AM
turbo ES turbo ES is offline
Underdrive Pulleys A Joke?
i have a stealth auto dohc and 8 inch wide tires which are very soft, but i was wondering if any body else who has the same setup as me can even get the tires to spin without turning? also has anyone tried underdrive pulleys and do they do anything but make your lights dim? i have seen the light weight but same size pulleys from 3sx performance or somthn but do they work either?
Old 06-16-2005, 08:42 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Underdrive Pulleys A Joke?
I dont have them but know of plenty of people with one and yes they work. THe 3sx ones are at a major advantage being of the same size. Most of the power is gained from loss of weight, not loss of size.
Old 06-16-2005, 10:11 AM
2old 2old is offline
I am not sure what my tire width is... Doing calculation 245mm -> 9.6inch? Anyways I am running a summer compound and pretty much no... I can get them to squeak if I screw up my launch (it's manual) but I can't spin them unless it's in the rain...
Yes the pulleys help... I don't have it but put in a lightweight flywheel (where you can reduce a little more rotating mass) and you can definitely tell when you accelerate in first and second gear. Although it also makes your car idle a little funny while the ECU tries to figure out how much gas it takes to slow down the engine without stalling it.
Old 06-16-2005, 01:11 PM
Igovert500's Avatar
blue + red light magnet
There is a debate as to the safety of underdrive pulleys. If I were you, I'd do a search and at least read up a bit more on them, so you can make your own decision.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 06-16-2005, 07:56 PM
Hotshot8792 Hotshot8792 is offline
the 3sx lightweight pulley is good and wont damage anything
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 06-17-2005, 03:20 AM
3KSL95's Avatar
3KSL95 3KSL95 is offline
Send a message via AIM to 3KSL95
I have 255 45 zr17's and if i launch above 2000 rpms it does nothing but spin and they will give a pretty good squall everytime i power shift into second so if you cant spin the tires on your 3s theres somethin wrong with it. And yes the underdrive pulleys are great.
1995 3000GT SL (RED)
My mods:
Custom true dual exhaust with x pipe
K&N FIPK
17 inch forged aluminum billet rims from WELD EVO
Old 06-17-2005, 10:24 AM
LOL! My car is 13 years old... If I dropped the clutch while reving the engine, something's gonna break.
Old 06-17-2005, 01:35 PM
Wischmaster's Avatar
Wischmaster Wischmaster is offline
My car is 14 years old... it seems to hold up just fine.
Old 06-17-2005, 04:40 PM
Stealthee's Avatar
Bad compression, bad oil consumption and 245 tires and my SOHC will smoke the shit out of the tires.
Old 06-19-2005, 02:37 PM
mine is an auto though it will spin if i turn though and if the pavement is slick and wet but not on dry
