Go Back   Automotive Forums Car Chat > Audi > A4 | S4 | RS4 | A5 > '94 - '01
Old 06-15-2005, 09:09 PM
dans-peedy dans-peedy is offline
Question neeed help,possible turbo problem
Hy there.I'm new in this forum so please be patient with me!
My big problem this days is my '99 A4 quatro 1.8T. I found an oil leak in the pipe that comes from the turbo and goes to the intercooler(if i'm not wrong).I saw the leak on the flor and i just disconected the pipe that is right under the bumper,(front of the engine) and then oil came out from that. The wierd thing is that i don't see any smoke coming out the muffler,and i mean no skome at all,like everything is ok,and the car runs good ,too. If any of you guys could give me a hint on how to check if the turbo is running good. I can not think of something else than the turbocharger that could cause the leak,so i guess it has an internal damage.I could use some help with this turbo(k03 i belive it is),if you know where i can find parts for it.Thanks!
Old 06-16-2005, 02:41 PM
Torsen Torsen is offline
Re: neeed help,possible turbo problem
If the pipe goes from the intercooler to the turbo then thats a water pipe, I think. Anyway, I got a quote for servicing my K03 turbos. It was cheaper to get fully remanufactured turbos in exchange. I didn't do it though cos K04s are not much more money. A K04 would make your 1.8T fly(not literaly)
Old 06-16-2005, 04:00 PM
Re: Re: neeed help,possible turbo problem
thanks for the advice! Do you know if the K04 bolts right on,and do i need to change the computers software or any kind of tunning? I belive the hose from the turbo to the intercooler is for air though because i didn't see any water ,just the oil leaking from the turbocharger, i guess.
You're welcome to give me some tips wher to buy a remanufactured good K03 or K04 charger if you know. Thanks a lot!
Old 06-16-2005, 08:01 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like your oil seals in the turbo blew out =(
But that means big =) cuz its time for an upgrade... which is highly needed due to the underpowered 150hp stock car =(
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
