Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-15-2005, 08:07 PM
talkenigma talkenigma is offline
Remote control door lock reciever
Can anybody tell me where or how to find the location of the rcdlr on a 2002 Impala . Dealer said it is bad but if possible I will replace it myself
Old 06-22-2005, 01:38 PM
slacker_53's Avatar
slacker_53 slacker_53 is offline
Okay, here you go, and with pictures if I can figure it out.
The reciever is located between the windshield and the dash pad, under the plastic molding that is about four inches wide. It's basically located between the steering wheel and the radio visually, if you get the picture. Actually it's just to the left of the little plastic bulb located ON the plastic molding.
First remove the fuse panel cover on the driver's side.
www.geocities.com/tbuckit1/pic1.jpg
Then remove the molding that runs up the windshield pillar. Start at the rear of the door opening and just start pulling it loose, it's only a series of clips.
www.geocities.com/tbuckit1/pic2.jpg
Start pulling up the molding between the windshield and the dash pad, starting at the driver's side. It just snaps in also. You won't have to remove it completely, just past the right of center. If you look just to the left of the louvers in the molding, you can spot the reciever.
www.geocities.com/tbuckit1/pic3.jpg
Just reach in pop it out and unplug it, plug in the new one and go back together in reverse order. Literally a 15 minute job.
By the way the GM part# is 15042969 and my cost was $65.69.
-slacker
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 06-22-2005, 05:19 PM
remote control door lock reciever
Appreciate the info but the real problem turned out to be the BCM . Dealer shotgunnned the rcdlr diagnosis.
