Old 06-15-2005, 05:41 PM
Beamer17 Beamer17 is offline
Send a message via AIM to Beamer17 Send a message via MSN to Beamer17
turn signals
hii have a 95 grand am and my tunr signals do not work the bulbs are fine the fuses are fine. my hazards work just fine but the turn signals do not. if u use them then the brake light on the side u have turned on does not work since normally the tuern signal is blinking on that light. any ideas to what this could be
Old 06-15-2005, 06:51 PM
Degtr Degtr is offline
Re: turn signals
Since everything else you described is fine, I would guess the switch or relay is bad.
Old 06-15-2005, 09:30 PM
Knifeblade Knifeblade is offline
Re: turn signals
Another possible is the flasher unit
Old 06-15-2005, 11:56 PM
where would all of those be located do any of you know
Old 06-16-2005, 08:55 AM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
The switch is in the steering column, with the headlight switch and no the steering wheel does not have to come off, the flasher unit is under the dash on the drivers side in a unit with the hazzard flasher and the door chime.
