Old 06-15-2005, 05:19 PM
Buechman Buechman is offline
High Idle
My 91 CX had been recently put back on the road after about 3 months sitting time and was fine at first then i got the old check engine light and a pretty high idle. I tried changing what it was set at but the lowest i can get it set to was still way too high. I also checked for leaks.. no dice. Pretty stumped. I checked all my grounds thinking maybe that would do something but no. Also it wont let me change into gear from park. AT by the way. Any help would be great.
Old 06-15-2005, 05:43 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: High Idle
check the how many times the LED on the ECU blinks and tell us, that will be the error code and it helps diagnose the problem. The ECU is under the carpet on the passenger side foot well.
Old 06-15-2005, 06:20 PM
Re: High Idle
I checked it over and over but it just stays on constantly, no blinks
Old 06-16-2005, 04:38 PM
Re: High Idle
I was thinking maybe the IAC valve on the right of the manifold? I Cleaned the carb in and out throttle body too. I still dont know how i'm not getting a blink or flash from the ECU.
Old 06-16-2005, 11:14 PM
Re: High Idle
carb?? are you sure you are checking the ECU light? If it's solid then it might be busted.
Old 06-21-2005, 05:25 PM
Re: High Idle
its fuel injected sorry, i cleaned the throttle body and is there wires i need to jump to get the light or should the ecu flash anyway?
Old 06-21-2005, 05:55 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: High Idle
if you turn the key to the on position, the ECU LED will flash the code. you dont need to jump anything. its under the carpet on the passenger side. theres a sightglass on top of the ECU, so you dont need to unbolt anything
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-21-2005, 07:37 PM
Re: High Idle
thats what u thought, but the light doesnt flash, just stays on, maybe it is toast
Old 06-21-2005, 07:38 PM
Re: High Idle
thats what i thought i meant. i'll try and see if i can get another one and try it out to see
