Old 06-15-2005, 01:32 PM
freqz freqz is offline
1992 Eclipse GS Turbo for sale
I have a 1992 eclipse turbo up for sale. The car is located in Shelby Twp (48315) Michigan. For information see the following link.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4556664951
This was a fun car but I also have a 2000 Trans-am WS6 that I drive now and a jeep I need to start working on so this must go. It has treated me very well and as you'll see I've replaced some of the major wear items already on it.
Old 06-16-2005, 10:59 PM
This is a Great little car and pretty fast too. I bought this car for a dealer in march 2003. I have used this car daily and it has never let me down. Below is a list of everything that I have personally have done or had done to this car since I have owned it.
This is a list to the best of my knowledge that had been done on this car.
Drivers side tie rod
Both left and right driveshafts
front struts
Front engine mount (New oem Mount, Filled in gaps with 80 urethane )
solid Turbo intake tube
Factory Air box has been cut out to allow more fresh air in.
battery
plugs
wires
fuel filter
timing belt (done as preventive maintance)
water pump
Thermostat
Alternator
Read window defogger switch
ignition module
4 kicker speakers that replaced the factory speakers ( doors and rear piller)
It starts right up, the Turbo spools up quick and you can really feel the power. I have been told that the turbo looks to be fairly new. (I'm not really a small engine turbo guy so I really cannot tell you more on that subject)
Everything works on this car accept the fog lights (I do not know if its the switch or maybe just the light bulbs are bad. Personally I really didn't care much as to me that was very minor), The AC does work but the compressor has a small leak someplace around the unit or the unit itself. BUT I usually just get it filled once a year and it will last from now till next year. ( When I had it filled I had the repair shop add the dye so the leak could be pinpointed and that's where it stands, Either the compressor or the fittings to it). Lastly the flex pipe on the exhaust should be replace sometime in the future. ( it's not loud but it is wearing)
I also have the NEW OEM rear engine mount as well that I HAVE NOT installed. This will be included with the car as well as the 80 urethane mix IF you want to beef the mount up as I did on the front.
Also included is a 1990- 1998 Clinton Repair Manual.
The radio that is in the Pictures IS NOT INCLUDED !!!!!!
I will install back the factory stock radio / cassette player
Old 06-16-2005, 11:01 PM
V T E C H's Avatar
V T E C H V T E C H is offline
Re: 1992 Eclipse GS Turbo for sale
Dont mean to be an ass, but at least vacume it out before you post pics on ebay. :P
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 06-20-2005, 07:58 PM
I know what your saying. I wanted to just get the auction up as quick as I could. In need of the money so that was the first thing on my mind. If you take a look now you'll see what it now looks like all cleaned up.
